Siemens MP270B Via Modbus
teh
Supporting Member
Nov 2002
140
Hi Folks,
Can Siemens MP 270B Communication with Modbus Protocol?
Is it Required the addtional modbus software/Tools?
Regards
Note:
In Protool I notice that only the CPU types Modicon 984, 984-785 and TSX quantum are available.
The selected CPU type probably decides the limits to the available memory addresses. If you have another CPU type than the ones that can be seleced, then you must take care to use a memory area that could be used in the CPU you select.
Try to select a CPU and to define some tags. Protool/Win CC Flex will protest if the address is not possible on the selected CPU.
Hello. I have a problem with a MP270B, I cant communicate via IF2 RS232 port. I have made an OS update via the MPI port, but still having problems...
3,757
Hello, My client says that the clock was changed automatically to year 2006 without anyone entering the control panel. Is this possible in some...
2,105
HI everyone, i am new to Siemens plc programming and i am in need of some help. yesterday we had an S7-1200 CPU 1214C fail to turn on an output to...
142
Hi PLC people, think about this scenario: The PLC is somehow connected to the same network with the facilities` network. Then someone connects to...
78
Hello everyone, I've had this issue for the last 2 days where I try to assign the profisafe address to an IO block (6ES7 146-6FF00-0AB0) but when...
149
