Siemens MPI Network Between 2CPUS
MOeZ
Nov 2009
singapore
101
Dear All,
I would like to try out MPI communication between 2 CPU. I have CPU315-2-DP and CPU314. I am new and start test-writing myself by seeing others post. Now i want to test it data exchange between PLCs. Kindly guide me. an example would be very helpful and thanks
Bgrds,
phyoe
For MPI, use X_PUT and X_GET from the standard library under System Function Blocks.
If the communication must be coordinated between the CPUs then use X_SEND and X_RCV.
Select either block and hit F1 to get help.
Another way to communicate between CPUs connected over the MPI network is to setup global data. In simatic manager highlight the MPI network then chose Options>Define global data
Hello Dear,
Thanks for your fast reply(y). Actually, i have no idea at all. but i will study further more based on yours suggestion. Can i request some manual or sample?
Bgrds,
I am new here. I am also kind of new to working with Siemens plc's. Working on a machine that has a Siemens 313C plc & a touch panel TP177A, on...
2,149
Hi All, One of our clients wants to replace some obsolete VFD's on their plant. There are two S7-315-2DP plc's and drives are connected via...
3,464
We have an existing network of 5 Siemens S7 315 and 313 PLCs communicating via MPI. We want to connect a Contrologix PLC to the network that will...
2,465
Hello I am setting up a piece of epuipment and the cables for the Mpi Network were cut. there are 5 different racks with this machine, where the...
8,602
good morning, we have Siemens HMI MPI 377 19 inch, the screen is Black but its working, and we don't have backup. i have new screen, my...
3,884
