siemens newbie here, questions about OP27 and s7-300
archron
Apr 2016
bursa
hello everyone,
i m trying to rebuild an old machine sitting idle for many years. it has a OP27 panel and 2 CPUs (314 and 316). i did connect the plcs and manage to upload programs but since i couldnt manage to find a way to get symbol tables, comments and the old program was written in STL its all nonsense for me. the machine will get a quite work over as mechanically aswell so i need to program it from scratch anyways. this will be my first siemens apllication beside a couple of simple LOGO projects so bear with my stupid questions :)
here i go;
1- how to configure network in step7?
phisically cpu 314 and cpu 316 are connected each other via profibus ( a purpleish cable) and OP27 is connected to cpu 314 with profibus ( a blue cable ). is it correct to make one MPI line and connect both CPUs and OP there? addresses 2 and 4 for CPUs and 1 for OP27
2- how to connect OP27?
can i dowload programs with same mpi adapter i use for CPUs or do i need a different cable for that? if the second case is true i have found some cable connections for 15 pin - 9 pin, 3-3, 4-2 , 12-5. is this pin connection correct?
1. That seems correct.
Profibus cable is purple, and for a small MPI network you descibe you use Profibus cable and connectors. The connection will be daisy-chained via the profibus connectors. It is a worry that one of the cables is blue. If it is not a real profibus cable it may still work since MPI @ 187.5 kbps is quite forgiving.
2. You can download to the OP27 via MPI, or serially via RS232 and the IF2 port.
Here is a description of the cable needed for serial download:
http://www.plctalk.net/qanda/showpost.php?p=249583&postcount=3
The pins you described seems correct.
Hi - I am unfamiliar with Siemens PLCs but have been given ownership of an S7-300 CPU318-2 with IO and a network interface card at site. The PLC...
18
4,280
I picked up a Siemens S7 1200 from a buddy and I want to start fiddling around with it to learn about PLC's. I don't want to spend a lot of bucks...
2,470
I have a project I am working on that will be deployed at all of our sites (globally). Basically, we'll have a PLC that operates some fairly...
3,789
Hello Guys, Newbie with Siemens here. I will be configuring and deploying for a project of mine for WinCC redundancy. I have read this article...
7,315
Hi everyone, I am new here in this Siemens world.Any Ebook, Tutorial or guide to learn siemens step7 programming TIA portal, WinCC?
1,563
