Siemens OP 73
Yes you can.
Access the IO-field by going to it using the arrow buttons and then pressing enter when the desired IO-field has focus.
With the up and down arrows you can scroll throught the allowed selection of decimal numbers, which you can then select and confirm with enter.
Do note: you need to specify each number individually.
So for 358, you need to select 8, use the left arrow button to navigate to the next number, where you need to select 5 and again using the left arrow you move another decimal spot and select the 3. Enter confirms your selection.
Hello, I have a CPU 317-2DP Firmware Version V2.1.8. In TIA Portal only V2.6 is available, and there is no option to upgrade FW. Then I open it...
103
303
107
160
Hello, good morning, I have been having two problems with the Tia Portal software. The first is that I have installed it on my computer and...
197
