Siemens OP15A Problem
Göran
Feb 2009
Örebro
I have a problem with one OP15A 6AV3515-1EB00
The program is lost in it, and when I start it up I get the message
$006 COM-Transfer Fail -No:0 Sts: 8
From what I know that means that there is no connection between the OP and the Computer, but I have the cable attached, and both the cable and computer works fine to my other OPs.
Does any one have any Idé?
Hi Göran
I have exactly the same problem...do you know how to solve it now?
I am trying to retrieve configuration from a op15, can i do it using Protools Pro?
Thanks for your help
72
45
139
Hello, good morning, I have been having two problems with the Tia Portal software. The first is that I have installed it on my computer and...
172
Hello to all, I'm just starting with using CodeSys. Immediately, I have noticed that Codesys doesn't use data blocks like for example S7 does...
178
