Siemens OP77B <-> PC
Nov 2009
@ work
Hello,
I’m trying to set up communication between an OP77B and the PC,
Yes you read it correctly a PC and NOT a PLC.
The final goal is to control the terminal form out VB,
I have this working for a Cimrex20
I can load my programmes to the terminal and I’m using WinCC flexible compact 2008
Thx,
Ben
Hi guys, i am able to take back up from op7 dp and op77a but i am failure to take back up from op77b.i am using usb/ppi multimaster cable. 1p...
5,201
Hi, I'm trying to modify the OB77B screen, but it says I need to update the operating system because I'm using a newer version of WinCC. I'm using...
2,250
I am completely unfamiliar with Siemens programming but I have been asked to become familiar with it. I have a new copy of TIA Portal V11 SP2...
12,370
241
155
