Siemens OPN DB[MW]?
ylade
Sep 2007
Ireland
23
Hi All,
I wish to Open a DB that will be constantly changing.
Eg OPN DB [MW] My code will look at the data words/Dwords/Stings from this DB. However, I also need the Data locations to change for example
L 10
T MW 20
L 44
T MW 30
OPN DB [MW20] // Opn Data Block 10 ----THis Seems possible
L DBD [MW 30] // L Double Word 44 ----- THis does no?
Any Ideas?
THankso_O
Try this
L 44
SLD 3
T MD 30
L DBD[MD30]
Be carefull MW32 can't be used somewhere else in the program
Stl
U need to use the adress register.
Some SLD3 stuff.
L MW30
SLD3
LAR 1
L [AR1,p#0.0]
I think it's something like that, if not, STL specialists on this forum will help you further.
Hi All,
L 10
T MW 20
L 44
T MW 30
Any Ideas?
THankso_O
kay
yes, but I do like your indirect code more. (sounds *** kissing) 🍑
I don't use indirect adressing much as you all can see :).
I just used the code like he did :)
I don't really prefer one or the other.
I would say it depends on what his is triing to do. ;-)
278
161
Hi need help why this “failure 5 emergency stop “ appears at every startup in the morning ? Have to shut off main switch at least 10 times on...
19
311
125
Hi everyone hope you'll well. Is it possible for me to download a Crack version of tia portal v13..sorry to say this but the software is very...
202
