Siemens PG 631 programmer into S5 130K PLC
Carrington
Sep 2010
Nottingham
I am still trying to download programme from PLC to PG 631 unit with no success, I have tried in PLC run mode & stop mode no joy.The manual seems to suggest every time I want to try say mode 30 mode 21 has to be input first but that results in error cable, deleted by pressing 1 then fault 10 appears saying not allowed in this mode.Has anyone got one of these units that work who could help me.
Forget my question, the AS511 card was made after the bronze ages, your AS501 presumably before:D.
My first PLC project, a thousand years ago, was a S5110A / PG631. I think the prog. cable was a parallell version, and the program could be test-run in the PLC via the RAM in the PG. The 130K seem to be of the same type.
I indeed hope you consider to take this ancient PLC in a boat and row it into deep water and sink it silently there.
But - I found some links to manuals:
http://support.automation.siemens.com/GB/llisapi.dll?func=cslib.csinfo2&aktprim=99&lang=en
Here are 4 IDs to different manuals for the PG631:
22532363
19696894
19696681
19698875
There might be some oldies knowing more about this kind of equipment here: www.sps-forum.de
Good luck!
Kalle
Cannot download programmes from S5 130K PLC to PG 631. I think this is because I need the PG 631 to be in mode 21 but I cannot get it to go there...
1,748
I have a PG 631 programmer unit & the screen is in German but I have an English manual.I am connected to a S5 130K PLC via a 501 interface board...
3,223
Hello! Does anyone have a diagram for connecting serial port printer to PG631? PG631 has TTY/V.24 current loop printer output but I don´t know...
3,686
Hello everyone, I've had this issue for the last 2 days where I try to assign the profisafe address to an IO block (6ES7 146-6FF00-0AB0) but when...
64
Hello, good morning, I have been having two problems with the Tia Portal software. The first is that I have installed it on my computer and...
87
