Siemens pg675 PLC
rluce
Jul 2004
USA NY
We have A Siemens S5 150K PLC that we access with a PG675 CRT.
Can anyone tell us what we need to access and program this plc with a Lap Top (PC) (Software/Cable)
The pg675 has double 5 1/4 floppy drives.
Also how can we transfer files from the floppys to the PC. These files do not appeqar to be DOS files.
I think the files made by a PG675 might be pre-CPM, I cannot check it anymore because I've dumped mine some years agoo. Bad news is: the original Siemens software can import CPM files, but I'm not sure about PG675 files. I cannot test this either because I don't have any 5.25" drive left. I have not seen any third party software which can convert CPM S5 files to DOS versions. If you're using non-Siemens software (eg. S5 for Windows by IBH-Softec) you might need some other software to do that conversion first. This should be only conversion from CPM formatted disks to DOS formatted disks. Another drawback: where can you find a 5.25" drive for a laptop?
Kind regards,
(Jean-Pierre's comment above is referring to the original post of this image which was around the size of a football pitch)
from S5 reference guide .....
Ah, the memories ....
PG675 could work in two ways:
1. with a special floppy whith both the operating system and STEP5. (Squezed in with a shoehorn). That left the other floppy for the project. This worked quite well. Drawback: The project file was incompatible with S5-DOS.
2. with a large number of floppies whereon was the S5-DOS environment as well as the STEP5 programming system and utilities. It was incredible cumbersome, and thus people never used it.
I didnt know that you could convert the "one-floppy projects" to the S5-DOS projects (with the mentioned S5-KONVER utility). When the time came that the PG675 had to be pensioned we wrote the project to an EEPROM, and then read that with a newer PG710. We lost the comments etc. so it was quite a job to type them in again.
Wow, I think we used it in 1985-86...
PG675 need 2 5" disks - one with Programming software, one for data file.
I don't rememeber if it was a convertor to the PC based...
Cable was a 20ma current loop.
Yeah, S5 still use 20mA current-loop. But with a laptop it might be better (easier) to use a USB to current-loop converter. Nowadays it seems hard to find a laptop with an RS232 interface. That's a pity, because it was fairly easy (not to mention cheap) to construct an RS232 to current-loop converter.
Sorry about the 72" monitor remark, I simply couldn't stand the temptation :D .
Kind regards,
Can anyone tell me the steps needed to read a EPROM from an S5 on a Siemens PG675..??? Thanks
17
6,340
284
162
Hi need help why this “failure 5 emergency stop “ appears at every startup in the morning ? Have to shut off main switch at least 10 times on...
19
312
125
