Siemens PLCSIM v15
chopin
May 2012
Milton Keynes
210
Hello guys,
Need some help on siemens plc simulator. I am trying to download my trial project but it cannot find a controller to connect to.
The issue is only when I am trying to use 1500 or ET series CPU it is working fine with 1200.
Any ideas where could be the issue o_O?
Anybody had similar problems?
Sim version 15 seems to be broken. My team is having the same issue using it on all of our V15 setups. Was told Siemens was aware of the issue, and working on a fix. Currently just using spare CPUs for testing with.
I've been using PLCSIM V15.0 for the last couple of months for simulation. PLCSIM crashes if you attempt to change to the "detailed" view though.
Thanks, I am trying on VMWare Win 7 Ultimate SP1. Maybe there lies the issue,
I will try to reinstall PLC Sim first and if it still will not work will try on Win 10 and see the outcome.
Hi, I am trying to communicate with Siemens S7 PLCSim through InTouch (Wonderware). I am running a Windows 7 VM on a MacBook... I have Simatic...
5,854
I am currently working on a sizable project involving Siemens PCS7 on an H-system using WinCC for graphics. The project is still in development...
5,488
Ok so I know that SIMATIC S7-PLCSIM is out there to act as an emulator if you don't have a physical PLC to write and test programs with... but it...
8,740
I've got a nasty non-linear control loop problem to which I think I have a solution, but I need to be able to thoroughly test it and if possible...
3,344
Hi all, I am trying to do simulation by using PLCSIM ver 5.4 sp4 and Simatic Net ver 6.1 (iFIX SCADA). But I cant able to communicate each...
7,347
