SIEMENS Processors
Iman
Jul 2010
Tehran
172
Hi guys,
Does anybody know any information about the processor of Siemens CPU module like CPU 414-3PN/DP? Information like the clock frequency of the processor.
Thanks,
As far as I know the microprocessor in the S7-400 series is a Siemens own design.
In the S7-300, the micorprocessors are from Infineon (owned by Siemens) and MIPS (319).
What do you need to know this for apart from curiosity ? You cannot access the microprocessor directly.
Thank you,
In fact, I want to find a logical relation between cpu clock frequency and the speed of instruction in SIEMENS like bit operation and the more complex ones. And also in the end I want to conclude that how much clock do we need to execute a specific instruction like AND, OR and ...
Thank you,
In my previous mail, there is link to file that gives you response to all that questions.
Hello, I have a CPU 317-2DP Firmware Version V2.1.8. In TIA Portal only V2.6 is available, and there is no option to upgrade FW. Then I open it...
64
HI everyone, i am new to Siemens plc programming and i am in need of some help. yesterday we had an S7-1200 CPU 1214C fail to turn on an output to...
221
Hi PLC people, think about this scenario: The PLC is somehow connected to the same network with the facilities` network. Then someone connects to...
93
Hello everyone, I've had this issue for the last 2 days where I try to assign the profisafe address to an IO block (6ES7 146-6FF00-0AB0) but when...
159
Hello, good morning, I have been having two problems with the Tia Portal software. The first is that I have installed it on my computer and...
194
