Siemens PTO module with attention deficit disorder
panic mode
May 2003
Toronto, Canada
1,963
Hi everyone,
We are using ET200S I/Os which are controlled by S7-317F-PN/DP CPU.
One of the modules acts strangely. It is 6ES7138-4DD00-0AB0 and normally it seem to behave normal except that if powered on but not talked to (no commands) for some time (about an hour), it stops responding. It is used to produce pulse train driving small actuator. Cycle time is very long and there will be long periods without activity for this particular actuator. Is there anything that we may have overlooked? We could of course send it a pulse forward then pulse reverse every 15-20 minutes but this is ridiculous. Used IM is 151 HF (6ES7151-1BA01-0AB0). The manual (ET 200S Technological Functions, Operating Instructions 04/2008) mentions some restrictions of the 2Pulse module with certain IM's but it seems not to be the case here. This problem is not one corrected by the firmware updates either. Any ideas?
panic mode
actually, once it stops talking, there is no fault and one can't reed anything from module anymore. i agree, to me problem also seem to be internal to the module.
277
161
Hi need help why this “failure 5 emergency stop “ appears at every startup in the morning ? Have to shut off main switch at least 10 times on...
19
311
125
Hi everyone hope you'll well. Is it possible for me to download a Crack version of tia portal v13..sorry to say this but the software is very...
200
