We are having a problem in our paper impregnating factory where the tension changes too fast during the joint sequence.
Example :
Running tension = 600 N/m
Tension during joint = 420 N/m
When the line is running and the joint comes (the reel changes at the unwinder), the program takes up the settings from [Tension during joint] immediately, without any kind of ramp -function, which cause´s the line tension to drop too fast and the line "falls on the ground".
I am supposed to solve this situation somehow, but i have no kind of experience how to make some kind of a ramp generator which decreases the tension step by step, during some amount of time, instead of decreasing it immediately.
Any kind of help will be appreciated
The software im using :
STEP 7 - V5.3 + SP3
Example :
STEP 7 - V5.3 + SP3
