Siemens Rotary Servo In Torque Mode
JD
Also trace the torque and compare what the torque sensor shows and what the drive trace torque shows
I hope that makes sense
Just to close the loop on this I worked for hours on tuning the servos in yesterday. Played with the P and I until I was able to reduce the torque to an acceptable level. Siemens then supported me today while we did some runs and they agreed that the torque was within the motors capabilities. So the strategy that I have with the technology objects is sufficient without have to switch to a direct torque mode.
Thanks to all the members who jumped in on this.
Currently, I am using an old siemens encoder p/n:6fx2001-5ss24, 25bit, 10-30V with their own mating connector. SSI interface. Since the...
2,883
Hello, good morning, I have been having two problems with the Tia Portal software. The first is that I have installed it on my computer and...
45
Hello to all, I'm just starting with using CodeSys. Immediately, I have noticed that Codesys doesn't use data blocks like for example S7 does...
131
104
328
