Hi, how to make timer in Step7 to behave like RTO timer in AB?
In AB RTO is working while iput is 1. When input is 0 RTO stops and again when input is 1 it continue working from existing value until it reaches preset value. There is retentive on delay in Step7 but it continue to work if input is changed from 1 to 0.
For example timer is supposed to timing 10 sec. If input is stopped (1 -> 0) at 5th sec. timer will retain current value, and when input change from 0 to 1 it will continue working from that value (5) to the end (10 s).
Any help would be greatly appreciated
