Siemens S-200, 300, and 400
ceilingwalker
Mar 2010
Phoenix, AZ
1,586
Good day all. Could someone with Siemens PLC controls please tell me the difference between the S-200, S-300, and S-400? I have a project coming up that my superior wants me to use a Siemens PLC and I don't have much experience with them. Thank you
There are many differences, ill try to list some off the top of my head:
- the s7 200 uses a different programming software to the other 2
- 300 & 400 can generally be programmed in step 7 classic or the newer TIA.
- 200 have been replaced by 1200 which is programmed exclusively in TIA
- the capabilities and performance increase with each model with only the 400 capable of dual redundant cpus.
There's many other differences e.g. Io on base, scan time, max io, memory etc.
S7-200 = been discontinued
S7-300 = small to medium projects
S7-400 = medium to large projects
S7-1200 = small to medium-sized projects (successor to the S7-200)
S7-1500 = medium to large projects
This is a rough description of the individual systems, but the choice of system depends on the complexity of the control system, the size of "geographical" plant will be and the capabilities of the system.
So more information on the system, and we can give your a hint about what direction your choice should be.
Read more about the different Siemens systems here:
http://www.automation.siemens.com/s...n/brochure_simatic-controller_overview_en.pdf
:d
S7-300 = small to medium prices
S7-400 = medium to large prices
S7-1200 = small to medium-prices
S7-1500 = medium to large prices
:D
I have been working to get a Siemens driver library called libnodave to work with Advanced HMI to give access to Siemens PLCs. I have tested on...
26
34,518
Hi I need to set up a comm loss heartbeat between a Siemens s7-200 226 plc (Slave) and a Siemens s7-300 314c-2dp PLC (Master). They are...
3,159
Hi all what is the easiest way to get data out of an S7 and an S5 so it is available via OPC? I know that in AB speak, that RSLinx can act as...
2,166
Hi all, my client has an existing 300 system with 3 by 316/314 PLC's connected on an MPI system with "global data" shared between each. They have...
5,659
Hi guys, I'll be doing 2 projects using Siemens PLC, S7-200 and S7-300. Can someone please let me know what is the correct programming...
1,965
