Siemens S1200 Ethernet Connection
MarkNightingale
Sep 2010
In The VAT Shed
740
So I have finally had to bite the bullet and do some modifications to some Siemens PLC code written in TIA.
I have got both V10.5 and V11 professional versions.
I am trying to go online to the PLC but keep getting a message saying No accessible devices found in network.
There are 3 PLC's on the network and 2 HMI's with IP Addresses in the 192.168.0.xxx range and a subnet mask of 255.255.255.0. I have set my laptop with the same IP address 192.168.0.xxx and the same subnet mask.
I can ping all devices and get a reply back from all of the PLC's and the HMI's but cannot get online, upload or download from any of them.
I thought it might have something to do with my PG/PC interface, but have read that the TIA doesn't use this method.
I feel I am missing something really simple.
Thanks in advance for any help.
Mark
I have disabled my firewall and there is only one network that I can select.
I spoke to Siemens yesterday but even they didn't know why I couldn't see the PLC's.
I am getting a copy of the program later today so I will try again then.
Mark
80
321
166
Hi need help why this “failure 5 emergency stop “ appears at every startup in the morning ? Have to shut off main switch at least 10 times on...
19
313
i have two plc 1. s7-1212dc/dc/dc ip; 192.168.0.1 2. s7-1500 1513-1pn ip; 192.168.3.2 i need to get data from plc1 to plc2. any idea how to do...
127
