Siemens S5-115U 942 CPU
Chandrashekar
Nov 2005
riyadh
42
I have a problem with a CPU 942.
I can't seem to get the CPU into RUN, CPU 942B is showing error. Its STOP and QVZ and BASP LED light’s are in “ON” status. CPU is connected with four hardware (942B CPU and one digital Input and one digital output module and one analogue Input and one analogue output module) I replaced the CPU board with spare one and I also replaced all the modules one by one and also base board. But Still problem is same. I am attached I STACK status pictures and uploaded program from PLC.
Kindly help me to fix this problem
Regards
QVZ means that there was a timeout when attempting to access some IO.
I am guessing that there is a problem with accessing the middle module, which I am guessing is the one you haven't replaced. Is that some kind of COROS HMI module ? Good luck with that !
Maybe BSTACK will tell you where in the program the CPU goes to stop, and therefore which IO address is faulty.
Of course, I have to comment, the old S5 system should have been replaced 10 years ago.
Hi, I have tried with the cable IBH S5-USB-Adaptor, communicate with the PLC above, but I can not! The response of the technical assistance of...
3,670
Hi all, I'm a total newbie on Siemens so any help is appreciated. I managed to get hold of a laptop with S5 software installed, and also a cable...
5,604
Hello again, i have a old siemens S5 processor that stays in the stop mode. i have tried to place the run/stop switch from run to stop and the run...
10,679
I did this once before but it was about 30 years ago I just tried it on a plc this morning and,when i fitted the eeprom and downloaded the...
2,160
Hello, I have a question that is bugging me, hope someone can shed some light on this I have a STORK filler that i have just added a new CIP...
1,623
