Siemens 115u 943b change eprom to eeprom
cottagewood
Oct 2005
Kent
179
I did this once before but it was about 30 years ago
I just tried it on a plc this morning and,when i fitted the eeprom and downloaded the program but the plc wouldn't run.
I assume i should have done a plc delete and then downloaded but i bottled it as the machine needed to go back into production.
Am i correct in thinking that no matter what i delete, when i fit tbe original eprom back in the plc will be back to original ?.
Do s5s have a config and if so does it get stored on tbe eprom?
Thanks Garry,
I did read that thread but it's a bit confusing as someone on it states that an eeprom can't be loaded via a plc which I'm sure isn't true. I know an eprom needs to be programmed outside of the cpu but im pretty sure an eeprom can be loaded via the cpu.
Another thing that confused me, i first powered down and removed the eprom, then powered back up again, the plc was in run but no program seemed to be in it. I thought that the eprom was just for backup and that the plc should run without it , providing the battery is good. I didn't actually go online at that point to see if there was anything in the plc ram as i was under pressure not to hold up production
Hello friends I have a plc siemens S5 115u cpu 943 B machine was runing smoothly and stopped for break ,but when restarted the following...
8,855
Hello, I have a question that is bugging me, hope someone can shed some light on this I have a STORK filler that i have just added a new CIP...
1,620
Hi, I'm wondering if anyone can advise me on how to set up this card on the S5. I'm assuming I need to add some special blocks into the CPU to...
5,226
I have a problem with a CPU 942. I can't seem to get the CPU into RUN, CPU 942B is showing error. Its STOP and QVZ and BASP LED...
3,147
Hi all, has anyone got any ideas to help me out with a problematic 115U, I tried to start up one of our plants today that has not run for three...
23
5,300
