Siemens S5 308-C
dleehanson
May 2007
grand forks
If there are any Siemens S5 buffs out there, help would be great. I am working on an existing system that consists of a Siemens S5 with a 308-B profibus card and am attempting to upgrade it to a 308-C. In the Existing S5 program from programming block 1 there is a call to function block 192. In function block 192 there are 22 variable declarations that i need to translate. This machine was built in Germany. Listed below are the variables that are declared in this function block. Can anyone translate what they might be.
Variables: FB192
FREI f4.7
DBNR kf223
ADR kf244
DATW kf10
DRZ1 f136.3
DRZ2 f136.4
EIN f4.0
DREH f0.7
LOES f4.1
PARA f4.2
WAZE t12
ZEIT kt100.0
LANF f4.3
SIT f4.4
VER+ f3.6
VER- f3.7
STOE f4.5
ANAP kf0
ANAL fw202
ANAS fw202
ANUU f202.0
ANUI f202.0
If anyone can shed a little light on this.
I was under the impression that you could just change an IM308B for an IM308C card without any changes to the program itself, you just have to load the profibus configuration into the IM308C.. But maybe I am wrong on that, it has been known.
Anyway, this manual might shed some light on the subject for you. Section 7 should contain what you are after.
Paul
Hello, I have a Husky injection molding machine that uses a Siemens S5 PLC and has a 308-3uc11 profibus card. Something took out the 308c card...
1,557
Hi I am no siemens expert and have been asked to price for changing out an old obsolete HMI unit (it has a large keypad, lots of F keys and a 2...
7,932
Hi everyone; I need to change the configuration of an IM308-4UA12 module. For that, I need the old "COM ET100" software. The zipped package is...
2,511
227
153
