Siemens S5 CP1413 alternatives
phizza
Feb 2012
UK
Hi
We currently have a small network of desktop PC's that connect to some S5 PLCs via CP1413 cards and the H1 network. Does anybody have experience of using standard ethernet cards in place of the CP1413 cards?
Thanks in advance
Phizza
Hi
Thanks in advance
Phizza
Have a look at S5 Lan adapters by Process-informatik (and others)
this converts the PG port into Ethernet and you can even program via the LAN
Thanks for the reply. There are over 30 s5 plc's with each Programming port currently connected to a cp143 via a "monkey swing" cable to the H1 network. I've heard that it is possible to get a connection from a desktop pc NIC card to the H1 network by using softnet s7.
Cheers
Phizza
80
321
167
Hi need help why this “failure 5 emergency stop “ appears at every startup in the morning ? Have to shut off main switch at least 10 times on...
19
317
128
