mrtweaver
Ok in a previous post I mentioned about having S5 and trying to load the software. A poster gave me great advice and a link to download the S5 7.25 from siemens. And my first thing is I want to thank that poster.
I did find out that our IT dept did have the 7.2 version so that I could use the 7.25 update. The version I origionally was trying was 7.11. Both 7.11 and 7.2 are full versions not upgrades.
Now I did at first have 7.11 installed on my laptop. And I then installed 7.2. The tried the update.
The problem is when I try to run it on my laptop I get a NTVDE crash. I know this stands for NT Virtual Dos Environment.
So I first tried to install the software on the company desktop, I only installed the 7.2 and then the upgrade to 7.25 and it worked.
So then i borrowed my daughters laptop, she is running XP Pro same as mine. It has the same hardware and all of the same basic software. I did this so I have a backup system to use if mine crashes. Anyway I did the install on her system and again it worked great.
So that makes me wonder if something was left behind in the 7.11 install that is causing it not to work. Should I have done some sort of uninstall of the 7.11 before installing the 7.2? Did the 7.11 place something in the registry or in the system32 folder?
I dont know I have not used the siemens s5 before. this is the first time I have tried to use it.
I also dont know if I need to have the origional program files for the S5 or if I can attach to the PLC and download the program.
So anythings anyone can provide regarding this would be greatly appreciated.
Thanks and have a Happy Holidays and Merry Christmas
