timbo_uk
Are there any S5 gurus in here?
I have searched the forum for any info about the IP266 module, but found only one thread
We have some banding machines with a push arm controlled by the IP266 module. We had one go down on us yesterday. We have borrowed one from another machine (not running on this shift) to keep us running.
We need to get a replacement, either a new via our siemens supplier for about £1100, or a repair for around £600.
I am trying to establish whether we need to program the IP266 up, or the PLC writes the parameters (or program???) to the card.
I have never used these modules before, so I am trying to learn fast on my feet. I downloaded the manual from Siemens.
http://cache.automation.siemens.com/dnl_iis/jQ4MTA1AAAA_1107380_HB/IP266_%28e%29_OCR.pdf
But, to be brutally honest, some of it may as well be in German!
I also found the following info about the COM266 software:
http://support.automation.siemens.com/WW/skm/frameset.asp?url=%2FWW%2Fllisapi%2Edll%2F19981730%3Ffunc%3Dll%26objId%3D19981730%26objaction%3Dcsopen%26siteid%3Dcseus%26skm%3D1%26lang%3Den&Query=ip266&SearchArea=alle&id=19981730&F11Marker=true&siteid=cseus&query2=&modelled=&lang=en
We do not have this software, and never have. I have checked our old siemens PG and this did not have the software either
I have (as an example)worked out that data is transfered through input blocks (IB) from IP266 to PLC. For example fault codes come into the software on the S5 module via IB83 (as module is in slot 2) as a hex code.
We have virtually no comments in the S5 program file either.
I have found FB14 in the listing that looks to write something to the IP266 module:
But I am not sure what the KF +26 means.
Also I would have expected the EEPROM FB to be called in OB1
I am struggling to establish if we need to buy the COM266 software, plus if we can upload from the operating IP266 units.
I have attached a pdf printout of the program. Sorry I could not get it to format to the pages correctly!
Heres hoping sombody can advise me here.
FB 14 C:BND550ST.S5D LEN=19
Page 1
Segment 1
:L KF +26
:T QB 80
:L KF +0
:T QB 82
:BE
OB 1 C:BND550ST.S5D LEN=43
Page 1
Segment 1
:STL
:C DB 18
:JU FB 242
Z1 : IW 84
Z2 : DW 8
Z3=0 : F 100.7
Z32 : FW 26
Z31 : FW 28
:JU FB 243
Name IV:16
Z1 : IW 86
Z2 : DW 7
OV : F 100.7
FEH : F 100.7
Z3=0 : F 100.7
Z4=0 : F 100.7
Z3 : FW 46
Z4 : FW 48
:L FW 28
:L FW 46
:+F
:T FW 86
Segment 2
:AN I 82.0
:S F 13.2
:JC FB 3
:JU PB 1
:JU PB 2
:JU PB 4
:BE
OB 21 C:BND550ST.S5D LEN=9
Page 1
Segment 1
:JC FB 2
:BE
OB 22 C:BND550ST.S5D LEN=9
Page 1
Segment 1
:JC FB 2
:BE
OB 34 C:BND550ST.S5D LEN=8
Page 1
Segment 1
!F 0.7 F 0.7
+---]/[---+---------+---------+---------+---------+---------+---------+--(S )-!
! :BE
