Siemens S5 - Lauer PCS
nibsy342
Mar 2011
UK
Hi folks - I'm a new member to the forum and would appreciate some help if possible please. ;) I have numerous control systems consisting of Siemens S5-95/100U PLC's that are interfaced with Lauer PCS text display HMI's. I need to be able to connect to the PCS systems to re-program the output messages. I understand that I need 'PCSPRO' software which I don't mind buying, but I can't find anybody that has it. Also, what type of cable/pin-outs would I need?
many thanks for any input, cheers, 🍻 Pete.
I was faced with the exact same problem. I decided to replace the Lauer's with red lion HMI's as we couldnt support the Lauer's anymore
My problem was getting the program out so I could remake it, they had no information on what it was doing when it died, I had to find everything in the PLC then put buttons and switches to get them running until we got the software and cable before we could remake it
188
145
Hi need help why this “failure 5 emergency stop “ appears at every startup in the morning ? Have to shut off main switch at least 10 times on...
19
305
114
Hi everyone hope you'll well. Is it possible for me to download a Crack version of tia portal v13..sorry to say this but the software is very...
199
