Siemens S5 / Westinghouse PC503 PLC
Rhopac
Sep 2008
Libertyville IL.
I would like to get help with our Westinghouse PC503 made by Siemens. PLC is fine but our HMI/OIT unit made by Maple Systems, model WES460A stoped displaying information from PLC. This operator interface terminal had display program stored in RAM chip that was placed in smart socket with internal battery cell to keep the memory live. After 14 years of service this battery lost its voltage and program was lost from the chip. I have replaced smart socket with newone but I have no idea what kind of program was in this RAM to control our display. Can someone knowlidgeable with Siemens S5 PLC and interface communication let me know what type of program we are missing, what can we do or where to go for help? Our machine (F85/HS traveling head press)was made by Hudson Machinery but I'm not getting any help at all from them. I have also contacted Siemens and they have no idea ether. Only help I got was Maple Systems tech. support to identify bad smart socket but they don't know what our program was. I made a communication cable for the HMI unit and I have the software to talk to it but no clue what to do next. Thank you in advance for any help that you could provide. Best regards, Bernard
The PC500 range was Siemens S5 100 range re-branded Westinghouse.
The S5 100 = PC500; S5 102 = PC502 and S5 103 = PC503.
The interface on the CPU is AS511.
Have you a copy of the PLC program?
If you have it might help you find out what was being displayed on the HMI.(information may have been from FW/DW/I/Q areas)
Hi Moggie and thank you for your reply. I did not do anything with the PLC and the program in it. What do I need to read and print the program out or to save to HD or flopy? From PLC-DOC.com I just bought book and demo software IBHSoftec simulator for programing S5 PLCs to learn little more about them. Please let me know what should be my next step. Any info will be appreciated. Regards, Bernard
109
Hello, good morning, I have been having two problems with the Tia Portal software. The first is that I have installed it on my computer and...
155
Hello to all, I'm just starting with using CodeSys. Immediately, I have noticed that Codesys doesn't use data blocks like for example S7 does...
169
113
332
