Siemens S5 with Prolinx, trending using RSTrend !
ckchew666
Aug 2003
Malaysia
591
We quoting a project where there are two sets of redundant Siemens S5 (currently running). The customer need to do trending using AB RSTrend on a computer (ethernet). Thus, we are thinking to put in a Prolinx Profibus to Ethernet module to convert profibus to ethernet.
1) My questions is, do i need one prolinx or two prolinx convertor?
2) If ONE prolinx is used, we need to daisy chain the two redundant siemens into the Prolinx, is it a correct configuration?
3) I think the siemens PLC must always become Master in this case, right?
Anyone can clarify? Thanks.
Regards,
CK Chew
Still playing with the GuardPLC + Prolinx convertor <--- do not look good :(
20
Hello, good morning, I have been having two problems with the Tia Portal software. The first is that I have installed it on my computer and...
56
Hello to all, I'm just starting with using CodeSys. Immediately, I have noticed that Codesys doesn't use data blocks like for example S7 does...
151
108
328
