siemens S7-300 to another S7-300 PLC communication on ethenet
panthripu
Mar 2004
228
Hi
Once again your guidance is required.I am trying to learn how to set up the communiations between PLC on ethernet.
I have two S7-300 PLCs .1) 315-2AF03-0AB0 with CP 343-1EX11-0EX0 2) 315-2AG10-0AB0 with CP 341-1EX21-0XE0.
I configured the harware in both PLC and connected through a ethernet new switch.Up to here its ok.
Now when I try to find suitable block to use from library. which block should be used for send and receive data from other PLC.
I would appriciate if someone can explain in detail with the parameters.
PUT/GET or AG_SEND/AG_RECV.
Notice that you must use the blocks from the "SIMATIC_NET_CP" ... "CP 300" library in Simatic Manager.
There are sample projects on Siemens support website.
there is another problem when I use the Function below: there are 100 step in the DB200 there are 12 items for each step: Step 1------------...
4,438
RE:Another Q for Move data to different address(Siemens S7-300) Thank you again for this, However I wanna to ask about: If I receive a initial...
2,587
Thank you About L D[AR2,P#0.0] I found it very useful, and how can I make the 100 step automatic put the input value into DB200 , if I choose 1 ~...
1,852
117
Hello all. I have an ESA HMI that is connected to a Simatic S7-300 (CPU312). I have uploaded the program from the PLC which is written with Step7...
1,470
