Siemens S7-400 PLC communication
Jing Zhi
May 2004
BEIJING
Dear all
Also, my plant have this Siemens S7-400 PLc, now i have the Step 7 software in my laptop. my question:
1 what kind of cable i should be use for connect from PLC to laptop?
2. How can I download the programm from PLC to my laptop?
Best wishes
Charly Jing( P. R. of China)
1: If you have Windows 2000 or Windows XP, I recommend the new USB adapter. 6ES7972-0CB20-0XA0
ALternatives are:
Serial adapter. 6ES7972-0CA23-0XA0 (slow speed !).
CP5512 PCMIA adapter 6GK1551-2AA00 (Windows 2000 or Windows XP only !).
2: When you are online, you can use the function "upload station to PG". That will copy everything from the PLC to the laptop. But there will be no symbols or comments !
Hi try this out
1 Just use MPI cable,through protocol converter , rem. to have mpi card installed on your PG, go to set PC/PG menu and set the adress to 2,This is uploading station ,
Create a new file ie file New
Go to tool menue
select uploading station icon
pop window
select view
say OK.
it will upload station ie plc user programme without symbolic adressing
:rolleyes:
Good day, I need help locating/dowloading PLC Siemens Saphir SIO ACX32 driver for Proface GP-Pro/PBIII. I am in the process of upgrading a...
1,398
Hello Experts, I would like to seek advise on how or what tag i should use or do to get the PLC diagnostic buffer to know what is the root cause...
5,649
Dear Sir, I have a healthy profibus communication between SIEMENS PLC S7 400 and Allen Bradley drive PF700 using 20-comm-p profibus dp module...
2,826
Hi good morning all... First, I want to know what is the role of subroutine program in PLC programmming and type of subroutines how its...
2,113
Hello Everyone, I use PLC S7-400 with Ethernet module CP 443-1 and i want to communicate with My galaxy via DAServer. I configure my PLC with...
3,414
