Siemens S7 and A-B SLC-5/05 communications
cbattles
Dec 2008
Ellenton, FL
I am trying to find information related to communicating between a SLC-5/05 and Siemens S7 PLC. I've seen several options...
1) Use a Profinet IO Proxy and Component Based Automation
2) Insert a Profibus DP comms. module into the SLC rack to communicate via Profibus DP
Has anyone done this before and know if one solution would work better than another?
The Woodhead module SST-PFB-SLC http://www.woodhead.com/products/brad/bradcommunications/networkinterface/plcbackplanemodules/#2113
is probably the best method
Everyone, i am in the process of purchasing the Slc 500 version of software to support what we have and i have a question. Several of our...
792
I'm trying to connect a Siemens HMI (MP277) with an Allen Bradley SLC5/03. I understand that the channel 0 of of the AB CPU is RS232C, and can be...
13,415
Dear PLC experts, I would like to know if anybody has already successfully communicate an Allen-Bradley SLC 5/04 to Siemens TP177B Color PD/DP...
6,742
Hello All, I Have the following problem with Siemens SCL code . This code should do: It transform a DINT to String but also it made the string...
6,497
Hi All, I have siemens CPU-300 with DP port. which i am using as master for DP slave. Now i had some SLC IO which i want to connect to the same...
4,790
