Siemens S7 into to TOD
cjd1965
Apr 2007
UK
1,659
Hi
I have a MP377 and S7-300
I have a grid of days of the week and times for each day. The times are ints for hrs and mins (hrs=24hr clock)
How can I convert the ints to TOD for comparison with the returns of FC7/8 IEC functions?
Is this just a question of multiplying my ints to get m/secs?
Hi From what I can tell it is just a case of converting the hours and minutes required to milliseconds and adding together to get the TOD for a particular day so i will try that out tomorrow
Cheers
Hi this is what i came up with, seems to work OK but maybe not the best way
Code:
FUNCTION "INT To Time" : VOID
TITLE =
{ S7_language := '9(2) English (United Kingdom)  25.10.2009  15:07:45' }
VERSION : 0.1
VAR_INPUT
  Duration_Hr : INT ;
  Duration_Min : INT ;
END_VAR
VAR_OUTPUT
  RunTime : TIME ;
END_VAR
VAR_TEMP
  Dint_Duration_Hr : DINT ;
  Dint_Duration_Min : DINT ;
  Dint_Duration_Hr_T : DINT ;
  Dint_Duration_Min_T : DINT ;
END_VAR
BEGIN
NETWORK
TITLE =
      A(    ;
      L     #Duration_Hr;
      ITD   ;
      T     #Dint_Duration_Hr;
      SET   ;
      SAVE  ;
      CLR   ;
      A     BR;
      JNB   _001;
      L     #Dint_Duration_Hr;
      L     L#3600000;
      *D    ;
      T     #Dint_Duration_Hr_T;
_001: NOP   0;
NETWORK
TITLE =
      A(    ;
      L     #Duration_Min;
      ITD   ;
      T     #Dint_Duration_Min;
      SET   ;
      SAVE  ;
      CLR   ;
      A     BR;
      JNB   _002;
      L     #Dint_Duration_Min;
      L     L#60000;
      *D    ;
      T     #Dint_Duration_Min_T;
_002: NOP   0;
NETWORK
TITLE =
      L     #Dint_Duration_Hr_T;
      L     #Dint_Duration_Min_T;
      +D    ;
      T     #RunTime;
      NOP   0;
END_FUNCTION
Here's an STL implementation:
Code:
      L     #Duration_Hr
      L     60
      *D
      L     #Duration_Min
      +D
      L     L#60000
      *D
      T     #RunTime
Hi
Thanks for that.. it is much more compact.
However shouldnt 60 be 3600000 to convert hours to milliseconds or am i missing a trick somewhere
EDIT
I just read read it and your correct.. I missed the conversion of hrs to minutes when i first looked
Cheers
I am using Tia Portal I used a block to write to the system time and it made it the TOD? Why does the TOD show up as a Double what type of data is...
4,112
Hello Could someone please help me with this query? I need a TOD value to be written to an s7-300 PLC from a SCADA. I have already created a...
2,968
I have never had the pleasure of working with a "Thermistor" until now and have a question. The Thermistor is a 10KOhm 4-20mA 2-wire device and I...
40
Hello, I have a CPU 317-2DP Firmware Version V2.1.8. In TIA Portal only V2.6 is available, and there is no option to upgrade FW. Then I open it...
166
HI everyone, i am new to Siemens plc programming and i am in need of some help. yesterday we had an S7-1200 CPU 1214C fail to turn on an output to...
387
