Siemens S7 - Report System Error...
svoicum
Sep 2006
Cluj
43
Hello everybody... after reading the other topics I came accross Report System Error. I configured it correctly, I think, I can see the errors using CPU Messages, but I don't know how to view them using a HMI or in my SCADA, using OPC Server. Could someone please help me?
Thanks in advance and all the best!
Voicu Stanese
I am using Siemens KTP600 Basic color PN Portrait, the PLC is ET200s (IM151-8 PN/DP CPU), my comunication is via Ethernet and when I try to access Alarm Settings the Alarms procedures are all disabled and I can't turn ON Simatic SFM. Is there a way to read the DB which contains the errors, I also need to display them on SCADA (not WinCC), using OPC Server (via S7).
Later edit:
The HMI that I'm using does not support S7_Alarms... bugger...:cry:
Does anybody know how could I read the CPU Messages using DBs and OPC Server?:confused::unsure:
Hello! Im having trouble with the Report System Error function in Siemens S7. I generated the alarms a while back, and now i have added more...
2,188
Hi, i am using siemens v13 portal for hmi. i am getting promblem to generate reports.please give me suggetion on how to generate report in...
1,058
Can someone give me some pointers.... I'd like to generate a daily report of all the alarms, warnings and messages generated by a machine, and...
6,247
Has anyone ever tried to print to a non-standard printer as listed in the accepted printers from the MP370 list...
2,638
Hello to everyone!!! I have a problem in programming a plc. The plc i use is the siemens S7-300 CPU313c. The problem is that i don't know how to...
2,995
