Siemens S7 SIL2 query
iknowsomeplc
Apr 2002
USA
199
Hello Siemens experts there,
A quick query regarding SIL2
Is it manadatory to setup redundant controllers to achieve SIL2 ? Or a standalone controller can be SIL2 complaint with Siemens PLCs?
I'm not that familliar with SIL but I'd think that if the risk assesment highlighted PLC failure as being dangerous then you ought to be considdering a failsafe PLC rather than redundancy.
Nick
Hello everyone, I've had this issue for the last 2 days where I try to assign the profisafe address to an IO block (6ES7 146-6FF00-0AB0) but when...
82
Hello, good morning, I have been having two problems with the Tia Portal software. The first is that I have installed it on my computer and...
126
Hello to all, I'm just starting with using CodeSys. Immediately, I have noticed that Codesys doesn't use data blocks like for example S7 does...
164
111
330
