Siemens S7 Teleservice
S7Guy
Nov 2003
Dayton, Ohio
1,250
Anyone here have experience with Siemens S7 Teleservice? I'm in a bind, and need to download a hardward config to a remote PLC, but I can't create a new "plant" in the Teleservice connections. It worked fine with V5.1, but I upgraded to V5.2 and now when I right click to add "New Plant", I get the following error: "The configuration files for the modem driver are inconsistent".
I've looked at all of the modem properties, and can't find anything that jumps out at me. Anyone ever see this message before?
S7Guy,
there is a FAQ about an error message that sort-of sounds like what you describe. Can it be that you simply must set the online connection to "TS adapter" ? Its just a long shot.
QUESTION:
What is the reason for the error message "No or inconsistent registration data found when accessing the registry " ?
ANSWER:
Check the interface settings in the SIMATIC Manager under Tools->Set PC/PG interface:
PC Adapter -> WRONG
TS Adapter -> RIGHT
Entry ID:631640
Sidenote:
Boy, the fonts look real weird while editing this. It will be interesting to see how it comes out in the end.
edit: It came out only half-weird :)
Excuse my ignorance. I've only worked on Mitsubishi Q-series PLC's, now I'm working on S7 for first time with no training. I'm trying to set up...
1,217
Hi Guys, Got abit of a problem trying to get a Siemens TS Adapter II working inhouse. Got the TS Adapter connected to the phone line and the MPI...
1,975
Hi people! I want to use Teleservice Siemens software v5.2 for the first time and I don't know exactly how it works. I just want to make some...
2,822
Hi' I am having some problems connecting to my Plc by siemens teleservice. At the Plc i have a Zyxel omni 56K modem connected to at standart PC...
6,146
HI everyone, i am new to Siemens plc programming and i am in need of some help. yesterday we had an S7-1200 CPU 1214C fail to turn on an output to...
52
