Siemens S7 To softing S5 PC link
You don't tell which kind of link and which interface in the S7 and the S5.
Anyway, I have done something similar with a S5Lan++ link that I bought here.
It was connected from a CP443-1 via the S5Lan++ to the 511-interface of a S5115U (95U and 948U did also work).
I used put/get -functions in the S7, the S5 has to be passive.
The 511-interface is not very performant. The throughput at best is 500ms, if you have compact data <= 64 Words, one put and one get telegram.
Kalle
I don't have the program anymore, but it was only one call of the FB GET and one FB PUT. You should find examples on the Siemens supplay pages.
I did only use DBs in my prog., but Markers was allowed as well.
Be sure that the IP-adress/subnet fits.
Make an active connection in the S7.
If you get trouble, it is likely caused by the TSAP (RACK/SLOT number) in the connection setup. I cannot remember what I used, but it could be it is mentioned in the PC-Link docu.
Good luck!
Kalle
HI everyone, i am new to Siemens plc programming and i am in need of some help. yesterday we had an S7-1200 CPU 1214C fail to turn on an output to...
160
Hi PLC people, think about this scenario: The PLC is somehow connected to the same network with the facilities` network. Then someone connects to...
84
Hello everyone, I've had this issue for the last 2 days where I try to assign the profisafe address to an IO block (6ES7 146-6FF00-0AB0) but when...
152
Hello, good morning, I have been having two problems with the Tia Portal software. The first is that I have installed it on my computer and...
184
Hello to all, I'm just starting with using CodeSys. Immediately, I have noticed that Codesys doesn't use data blocks like for example S7 does...
182
