siemens s71200
dilliganesh
Oct 2013
I AM DOING PROGRAM IN SIEMENS S7 PROFESSIONAL WHEN I AM COMPILING MY PROJECT I GOT 0 ERROR WITH 1 WARNING
MY WARNING MESSAGE I DISPLAYED BELOW
Inputs or outputs are used that do not exist in the configured hardware.,0,1,10:43:12 AM
HOW CAN I SOLVE THIS WARNING OR WEATHER MAY I CONSIDER THIS WARNING
Hello,
Just check Your physical addresses on I/O cards in hardware configuration and compare with addresses used in program and if they are not match, readdress them in hardware configuration.
Best regards
what r the hardware's ur using... may be module mismatch or else check the bus whether the modules are properly attached...
Also use the address that u have configured in the Harware config for Inputs & OP's
For ex using a non-exixting address of I/O may also rise this error..
Regards,
Nelliyan.G
If you are not sure of the configuration click add device then "unspecified" then the software will locate the hardware installed
Hi everyone I am completely new to using shift registers and am a bit stuck, my shift register works as should, it is for an overhead conveyor...
55
15,655
Hello; i'm having some troubles with a com test i'm handling. i have another end for it, but for now i would like to have : M241 in io_scanning...
3,496
I have a S71200 PLC connected to GSD board as a ProFinet I/O I am tasked with detecting when loss of communication happens I understand this...
2,762
hi friends i am new to siemens program i need to create plc logic to convert 4-20mA to 0 to 120 ppm value i don't know how to start the software...
1,844
Hi, Does any one have experience with sendind sms with s71200 through cp-1242-7? I would like to no the following? is TCON needed when sending...
2,733
