Siemens sfc 14-15
Plc_User
Dec 2005
Belgium
317
I have a configuration with a siemens 315-2dp that has a profibusslave : a profibusmodule of an ABB S4 robotcontroller?
type of the card : DSQC 352.
Hardware configuration in S7 is online (when looking online) no busfaults, by using the periferic inputs and outputs I can communicatie with the slave, but when I trie sfc 14-15 (dp read-write) to have consistency, I have an error output at the sfc 14-15 : 80B1 : "The length of the specified destination area is not identical to the user data
length configured with STEP 7."
Although I have configured 8 words in out in hardware and at the sfc14-15 I also have 8 words.
Could it be that sfc14-15 is not always supported by older slaves?
Are you sure the consistency is equal in both directions?
When I get such (for me) unknown gear, I allways use addresses in the process image area (below IO byte 127, cpu dependant). Then you can skip the (S)FCs, the CPU does this job for you, and you can read and write directly with the I/IB/IW/ID and Q/QB/QW/QD.
(hmmm, when I re-read this I suddenly got uncertain if it is correct for consistent data (Alzheimer strikes again)...but it is easy for you to test it.)
Kalle
Post a screen of sfc call and hw config of module.
Can any one...tell me how to install CFC and SFC packages in step7 5.5...???? When ever I open my siemens s7 project....a pop up windows tells CFC...
17,922
Hi everyone, this will probably be a simple question (I hope). I am looking for a siemens SFC87. I can't find it in any of our archives, nor can I...
2,816
can anyone plz guide me some information about SFB AND SFC
2,458
All I need some help, I need to read and write some data to a device on my Profibus DPV1 Network. The device in question is an Anybus Card...
5,377
hi everybody, i wanna learn sfc programming of siemens s7-200 plc, is there anyone who has documentation about it. thanks.
3,765
