Siemens SH1 Ethernet Card
coa
Jun 2004
96
Hi All,
Does anybody have experience using general ethernet care like 3COM in PC to communicate with SH1 network of Siemens S5. I want to find the solution for setup PC to communicate with S5 155U with CP1430. The price of Siemens CP1613 (PCI card) is quite expensive.
Thanks for your help
Coa,
I believe that Siemens sells a driver for using a general ethernet card like 3COM, instead of the CP1613. I am guessing that the driver is none too cheap either. I think it is called a SoftNet Driver. You may want to look into it. I am not positive that they have this for the S5. I thought they had it for the Simatic 505 TI, and for S7, but not sure on S5. Please let me know what you end up finding out.
Also, if you still do alot of S5 programming, you may want to take a look at FasTrak's Windows-based software which basically replaces the DOS Step 5. www.fast-soft.com. [email protected]
Coa,
You could use an normal ethernet card but you still need Softnet. Using a cp1613 communication card would eventualy make your life easier. We've done this on a PG before with a PCMCA card. We bought at first the one from Siemens but the wireconnection was broken and then afterwoods we but one of 3com and it worked fine.
Rudi
Hello, I have a CPU 317-2DP Firmware Version V2.1.8. In TIA Portal only V2.6 is available, and there is no option to upgrade FW. Then I open it...
97
HI everyone, i am new to Siemens plc programming and i am in need of some help. yesterday we had an S7-1200 CPU 1214C fail to turn on an output to...
298
Hi PLC people, think about this scenario: The PLC is somehow connected to the same network with the facilities` network. Then someone connects to...
105
Hello everyone, I've had this issue for the last 2 days where I try to assign the profisafe address to an IO block (6ES7 146-6FF00-0AB0) but when...
160
Hello, good morning, I have been having two problems with the Tia Portal software. The first is that I have installed it on my computer and...
197
