Siemens: shifting data within a DB
Do not use hard coded L addresses. Create an array of timestamps and use a named variable in the L area. Two positive edge detections also not required.
e.g.
I have attached a program that does exactly what you want byte by byte. Try it out. If you want to reverse the order, I think the source is included. If not, I can help you with it but you will get the idea.
This is how I did it.
Import the source and try.
Example:
Code:
      A     M      0.0
      FP    M      0.1
      =     M      0.2
      CALL  "DATA_SHIFT"
       IN_TRIGGER:=M0.2
       IN_SRCBLK :=DB402
       IN_SRCDST :=DB402
       IN_QDTM   :=10
       Done      :=#DONE
       _Ret_Val  :=#_RET
Best Regards.
188
145
Hi need help why this “failure 5 emergency stop “ appears at every startup in the morning ? Have to shut off main switch at least 10 times on...
19
305
114
Hi everyone hope you'll well. Is it possible for me to download a Crack version of tia portal v13..sorry to say this but the software is very...
198
