Siemens Simatic Manager & TIAPORTAL
shazad5444
Feb 2014
Houston
126
Friends, How we can find that in PLC loaded program is in Simatic Manager or in TIAPORTAL. I'm talking about S7 300 and 400.
Without knowing this can we upload program from PLC S7-300/400 in TIAPORTAL or SIMATIC MANAGER?
If program is downloaded with Simatic Manager then can we upload by TIAPORTAL?
In a 300, the code is just code. There are no tag names or comments, or any care about what software downloaded the project. It shouldn't matter which package you use to upload, but I doubt you'll be happy with the result no matter which you use.
MK42, thank you very much. I have doubt with file extensions, as Simatic Manager has its own extension and TIAPORTAL has it own.
I'm sorry, I thought you were talking about an online project you were uploading from the CPUS. S7 300 CPUs do not upload well, all you get is code, no useful descriptors.
If you have the offline project, you can migrate from Simatic Manager to TIA Portal, and it works pretty well. There is, however, no way to convert a Portal project back to Simatic Manager.
MK24, No you were right. Basically my question was regarding online, just also asked another question, now concept is clear. Bundle of thanks.
MK is not correct on this one. If your s7300 was programmed with TIA Portal
and you try to upload using Step7 V5.5 , you will get a message and upload will not continue
If you want a screenshot of this exact message- let me know
It worked in the V11 era, I was uploading in v5.5 to look at the compiled SCL code created by Portal.
If it's changed since then, that's good to know, thanks. I have a vague feeling that if I look far enough back in my post history, you've told me this before, and I'd forgotten :p
Interesting. Can you still go online and look at the code, or is that blocked as well?
Have you guys been able to successfully convert v5.5 files to TIAV13?
I have tried with a couple different projects, and yet to have success. It may be because of using older 300 series processors, but I am just curious if either of you have had good results?
So so
I always do it without the hardware. If there are option packages in your code i.e. pDiag etc. they have to be stripped out
You getting a lot of errors? Can you do a screenshot?
The next time it happens I will inquire with you, if you don't mind.
At this point I'll just try it every now and then, and if it doesn't work the first time I'm like "F$%K IT" and then I go back to v5.5, which I know will immediately work.
Been working on mostly s7-1200 stuff lately, so I am growing to like portal a little more than manager.
Hi , I am working on Siemens CPU 315-2DP(6es7315-2af03-0ab0) while working online i try to modify bool value memory address M33.3,M34.0 but it is...
2,340
Hi all! I have a client requesting quotation for us to install a jump box for remote updating of 3 Siemens S7-300 PLC's using Simatic Manager...
2,583
Hello, i have a project where i am asked to do address mapping of a ladder program in simatic manager for the power scada. i understand the ladder...
1,122
i was a problem in plc programming pc it windows was currepted it licence kay taken in pen drive and formate the whole programe after installation...
7,568
Good Evening , It has been several years since I used Siemens Software . I’m looking to purchase the software for a Siemens Simatic S7...
509
