Siemens Sinaut Modules Help
Coops
Dec 2004
103
I have a 313C-2DP Processor and a Siemens SINAUT 3V-IE Advanced Module....the software was working fine until I swapped the processor from a 315-2DP to a 313C-2DP...since i downloaded the software for the change the Sinaut module remains in stop and wont go in to run.
No system fault lights are up on the processor or sinaut module. When i try and do a module information on the Sinaut card it takes ages for it to come up and it says the unit is in run but no comms is taking place and the stop led is on.??????
When i try and view the other tabs in module information it freezes up and says 'No further Parallel upload possible. Too few resources.'
Any ideas?
Hello everyone, I've had this issue for the last 2 days where I try to assign the profisafe address to an IO block (6ES7 146-6FF00-0AB0) but when...
62
Hello, good morning, I have been having two problems with the Tia Portal software. The first is that I have installed it on my computer and...
83
Hello to all, I'm just starting with using CodeSys. Immediately, I have noticed that Codesys doesn't use data blocks like for example S7 does...
162
111
330
