siemens stl code cleaner way?
Tommycai
Aug 2011
KY
120
Hello I am incrementing db8.dbw0 by one in another fb and comparing it to acc1 whenever m199.7 is set would there be cleaner way to do this. I'm incrementing acc1 and comparing it and then jumping if RL0 = 1 to assign it something else.
A "M 199.7"
// loads db value into acc1
L db8.dbw0
//loads 0 into acc1 shifts acc1 to acc2
L 0
// the the two are equal rlo =1
==I
// if rlo = 1 jump to one
JC one
//increment acc1 by one and do comparison of db again
INC 1
==I
JC two
INC 1
==I
JC thre
INC 1
==I
JC for
INC 1
==I
JC fiv
INC 1
==I
JC six
INC 1
==I
JC sevn
INC 1
==I
JC eght
INC 1
==I
JC nine
so the code being like this should do the same?
JL db8.dbw0
JU one
JU two
JU thre
etc.
the assign something else is also an hmi input. Once one input is complete then it triggers m199.7 that loads the next db.dbw#
IS it possible to write this on a better way: L #db_Num2 L 121 ==I JNB _02 CALL "CONT_C" , "DB_reg_igla1"...
2,632
so the code I am trying to do loads two different values and then I try and tell if the value subtracted from the other value is less than 15 and...
4,301
I have just started out coding in STL and i have been given this piece of code to decipher L DIW [AR2,P#8.0] //LOAD DEST DB#...
15,612
Hi Siemens Experts, I am hoping someone can shed some light on my issue. I have uploaded the code from a S7-300 (317-2PN/DP) using Step 7...
693
I'm having trouble trying to convert this code to ladder, anyone able to help me? A M4.0 A M4.1 A M117.0 AN M17.7 A ( A I38.6 AN I3.7 O ( A M4.5...
1,216
