Siemens TM PosInput1 and absolute encoder
pisoj
Jul 2018
Osijek
Hello to you all!
I hope there is someone who can clarify some things to me.....
Equipment used:
  • TM PosInput1 (6ES7138-6BA00-0BA0) to read the encoder pulses
  • Baumer absolute encoder (EAM580-BAC.7L4G.12130.A-11206897)
Firs time I thought that there is something wrong with encoder, because we run the machine and pulses read were like random: 1000, 3498, 7820, 4000,234, 2500 and so on.
Then I disconnected the encoder and connected directly to the card. Rotating it by hand, I saw that pulses were going from X to 8192, then 8192 to 0, 0 to 8192.
One rotation is 4096 pulses.
Ok, next step was opening TMPosInput configuration in Step7.
Over there, I had following parameters:
  • Frame lenght: 25
  • Bit number LSB of position value: 0
  • Bit number of MSB position value: 12
So, my conclusion was: MSB - LSB = 13 bytes
2 on the power of 13 = 8192 pulses which corresponded to the reading.
I increased the MSB from 12 to 24, and yes maximum pulses I can read then are: 2 on the power of 25 = 33554132.
But then, I connected the encoder back, and we are almost in rollover value.
Then I increased the frame lenght to 32 bits.
MSB to 30 (because this is the maximum that you can put) and I guess now i should be able to read maximum value of 2 on the power of 31 = max DINT value.
So, my question here is actually.....
What exactly is the frame lenght parameter in Step7?
Should I leave it at 25 bits. Initially, I thought that this represents the information I found with help of data sheet of my encoder (12Bit Singleturn+13Bit multiturn = 25 Bit Frame lenght???).
But if this is the case, why should my encoder be limited to only 2 to power of 24 bits resolution? Because in the data sheet there is indication that max. encoder resolution is 32Bit.
Also, with increasing the MSB to higher value, I am actually increasing the upper limit of pulses I can read?
Thanks and if something is not clear, I will try to clarify it.
Sorry if the post is messy, I came from long shift and just want to get some sleep.
Cheers!
Good Afternoon , It has been decades since I have done anything with Siemens . What is the Siemens name of their Servo Product Line and what...
128
I'm using the Siemens PRONETA software to do some IO testing currently. I love the simplicity and fast testing capability. Does anyone know about...
82
Hi, First time user of S5 Siemens. Is there any solution on how to solve this kind of error. HMI OP7 $613 DB-error No. 11 (0: 15) Siemens PLC...
171
196
Hi all! Please inform me if i can make programing of the HMI SIEMENS IPC477D from TIA Portal software or not? I do not have WINCC software but...
112
