Sİemens Touch Panel Problems
mehkocak
Jan 2005
58
Hi guys
I have a siemens touch panel tp170 b mono.I can connect to the device but cannot transfer from panel to pc.I mean if I programmed it in protool and download the panel eveything is ok but when I want to upload from panel it is not possible.
Is there any one who can tell me the adjustment ( I did as in manual) that I should do and what can be the problem.
There is an enable upload selection in the display. (Somewhere in the control panel, transfer options or something like that). I never use the upload function so I'm not sure it works.
First of all, you should choose checkbox "Unable upload" in File->Download->Preferences, but if your project is too big and you don't have a memory card on your panel, you won't be able to download entire project, wich will be changable after uploading. In that case only a executive project code (not editable)will be accessible for uploading.
Sorry for my English.
Best regards
I have a problem, I'm running an AE Licence Manager on a Windows 2016 Server, and my Window Maker is on another separate Windows 2016 Server. My...
41
I require remote access to my projects that are away from home. I did some homework and decided that Weintek looked to have a good solution. Set...
210
Hi all. Customer wants analog faceplates really bad, even if we explained that it doesn't make much sense in his process. What he wants to see...
144
Hey guys, hoping someone here could give me a little advice. I'm working with a CR1000-04000 in Crimson 3.1 and I was interested in adding the...
149
Trying to export a Modern application for an upgrade to Intouch 2020 but I cannot export the application from the 2014 version because the export...
136
