Siemens TP Designer Software
hagos
Oct 2004
Africa
244
Dear Sparkies,
I have in hand all the legal software for Siemens PLC's & SCADA software.(Almost all versions of Simatic Manager,Siemens S5 software, IBH for S5 Windows, Microwin,ProTool, Simatic WinAC, WinCC for SCADA,LOGO..etc)
I was involved last week in a TP070 problem.The unit lost the program, so we sent to the vender where he mailed us a source application.For the first glance I thought that it could be downloaded using ProTool or WinCC Flex, but after consulting the manual I got to know that this TP070 needs a software called the TP designer(what this strange mix of software by Siemens?).Also to download it you need to get the 232-PPI cable with a computer that has a COM port and even when you use a USB to 232 converter you need to make sure that your converter alocates only COM1 or COM2.
Any ways the plant has a TP070 unit as spare(the last one in stock, we decide to replace it by TP177 micro which is WinCC Flex compatible in the future), for this reason I don't want to invest buying the TP designer software to use it in an obselete product(the TP070), I would appreciate if any one of you guys can advise on where could I get a free copy of the TP Designer.
Thanks to you all.
Hagos
Hi hagos.
I dont know the TP designer, maybe it is a pared down version of Protool.
If the project files have a .pdb extension, then I guess Protool can convert it to a TP170 f.eks. whereafter WinCC Flex can convert it to TP177.
are you sure its not on your MicroWin install cd ??
I think mine installed automatically
I have the option in Step 7-Micro/Win -> Tools -> TP Designer.
Its the third one down on the list just after TD200 wizard.
Dear Folks,
Thanks to your reply,
My Microwin is V4.0+SP1 (V4.0.1), it is not contained in the CD.
Regards
Hagos
Hi Josper,
The file extension is .tpf , it needs the TP desighner to be opened & downloaded to the TP070
Regards
Hagos
Mr. Chartier,
I have observed your long contributions to the Siemens forums.
Is the S7-200 Toolbox: TP-Designer for TP070 product available for download?
Thanks,
- Paul
A question to those who have the TP Designer, does it need an authorisation like the WinCC Flex?If it doesn't, is it legitimate to get it from a friend who has it and install it in my laptop?
Regards
Hagos
I have just installed Siemens TP designer software version 1.0.0.31 on my laptop. When I attempt to open a known-associated TP file with the...
17,800
I have spent some time trying to read a text-file into my report but without any good result... Is there anyone who knows how to do this? It...
3,750
Q
Hello All, I'm struggling with a easy task! I wish to create a simple pushbutton using Siemens TP Designer for a Siemens TP070 Touch Panel...
7,411
qeeplc
Q
I'm using the Siemens PRONETA software to do some IO testing currently. I love the simplicity and fast testing capability. Does anyone know about...
64
Hi, First time user of S5 Siemens. Is there any solution on how to solve this kind of error. HMI OP7 $613 DB-error No. 11 (0: 15) Siemens PLC...
157
