Siemens TP1200 Comfort Panel - SD Memory Card
LB90
Mar 2016
UK
Hi all,
On my project I have a TP1200 Comfort Panel (6AV2 124-0MC01-0AX0). Unfortunately I don't get to see the hardware until I get to site.
I understand it has 2 SD memory card slots.
I have a requirement to transfer archive data to an external SD card (which I'm hoping to insert into the 2nd slot).
My question is, can I archive data on the SIMATIC Memory Card, which I understand has to be inserted in slot 1?
If this is possible, I was then going to transfer the data to the 2nd SD card slot when I get the system event 'Low free space'.
Has anyone done this before/know if it's possible?
Thanks in advance.
LB
Only 1 SD card slot is available for storage. The other is a system card that is only used for backup/restore purposes.
I've got a whole bunch of L8's and a whole bunch of UDTs that use custom string lengths, but can't seem to figure out how to get these to...
536
I need to confirm that the can we convert the KTP1200 Basic PN to TP1200 Comfort HMI. I am using TIA Ver 14 and it shows the Device change option...
2,240
Guys, Is this touch panel limiting the types and size of SD/MMC card for data logging?
2,533
Good day, May I ask, what do I need to perform MIGRATION of HMI program from Siemens MP277 10" Touch hmi to TP1200. I already have WinCC Flexible...
164
I've got TIA portal v18, KTP1200 HMI. I want to add a slider bar (if that's the correct name for it) to an HMI screen. Baslcally, like a...
1,125
