Siemens TP170 micro Program Upload Porblem
riyajahamad
Jun 2002
Pune-India
133
Dear All,
I am trying to upload program from Siemens TP170 Micro HMI using Simatic ProSave V7.0, using 6ES7 901-3DB30-0XA0 cable (USB / PPI Multi-Master Cable).
When I open ProSave in Connection showing only "Serial" option, as my cable is USB I required USB in Connection option, anybody help me to configer the same.
THANKS IN ADVANCE.
Riyaz
Have you checked if there is any USB driver on your Prosave installation CD? Have you connected the USB cable to your PC? And if so, don't you need to install anything?
You should check if you have installed the driver, and I think that should work.
Thanks Tarin, I am using USB PPI Multimaster Cable for S7-200 PLC with Micro-Win software on same Laptop. But in ProSave V7.0 no option about USB cable, unable to connect TP170 micro.
Riyaz
my machine has siemens touch panel.TP170A now there is no backlight in the panel and i couldnt able to read easily. but program is there is...
1,533
Hi, I have a Siemens TP170B which I need to connect to a Mitsubishi Q02H. The only port available on the Q02H is the RS232 6 pin mini DIN...
3,671
Hi all! I have a problem i hope some one can help me with. My goal is to connect two siemens TP170-A panels with a siemens 314 plc, no problem...
6,319
Hi all I have a big problem with a touch panel of type SIEMENS TP 170-A. The panel is to slow, when I press a button it takes several of seconds...
7,835
211
