Siemens TP270-10" Screen Download problem with WinCC 2008
o4a0e1
Jul 2008
Sydney
Hi there,
I have a TP270-10" Screen that I cannot download to from WinCC Flex 2008... When in transfer mode, the TP270 has "Loader B 6.0.2.23" and in the WinCC 2008 "Device Settings Page" says that the screen is a TP270-10" 7.2.2.0
When I try and download "via MPI", it compiles and then stops...
Do I need to get the TP270's firmware flashed to 7.2.2.0? or am I just missing something?
If I do need to get it flashed, Is it something that I can do with a USB drive or do I need to send the screen back to Siemens.
Cheers!
Hi there,
Cheers!
Not sure about WinCCflex2008 but I managed to upgrade the firmware on a TP270-6" a while back.
You can do it through MPI if you find the latest firmware upgrade.
If not mistaken, I found the latest firmware some place on a Pro-Tool Pro CD.
The compiler will tell you what is wrong. Turn the "output" window on.
Anyway, if you connect via a PC Adapter, wether serial or USB, then it cannot be connected directly on the panel. It must be connected on a PLC via a Profibus connector with a PG Socket. The panel is then connected to this via a Profibus cable plus connector.
Because of this, it is easier to just connect via a serial crossed cable on the serial port.
Whichever method you use, you must enable the port for downloading via the Transfer applet in the Control Panel on the OP270.
In the latest version of WinCC Flex, you will be automatically prompted to update the firmware if it is needed. Flex then does it for you in one step.
Not really. There was the possibility to install a "NE2000 compatible" NIC in the CF slot. Unfortunately this type of card cannot be purchased from anywhere now.
For downloading the application, a serial nullmodem cable will be just fine - if somewhat slow.
Thanx
I'm using a Simatic PG, so have to do it via MPI... I've always found it easier with the serial cable and even with the usb--->serial adapters... First time via MPI with the programmer... And JesperMP, I thought the output window was always on during a compile? And I haven't had a lot of use of Flex... Protool was all us tradies needed... I'll check the output window when I next give it ago... Thx...
Hello all, Can anyone tell me how I may change the screen saver on a Siemens TP270 6" Touch Screen? I know that on a AB PV+ you can load an...
4,126
Hi guys, I have a trainer with a Siemens S7-315 Processor and a TP270 HMI, using an MPI adapter to connect. I have gone over every setting I can...
1,748
Hello everybody! I have a question about PLC CTI 2500 model C200. We have device with this controler but it hasn't a operating panel. I want...
1,834
Hello, A TP270 is giving us some problems when starting up. Namely, the touch function does not work for some time (like half an hour), but the...
3,323
Hello to all, My coleague is trying to download project with WinCCFlex 2007. He is using MPI/DP connection and it is OK. But he keeps getting...
4,411
