Siemens TP277 ethernet to CTI 2500
winklerlars
Supporting Member
Dec 2008
Brisbane
Can a Siemens TP277 communicate with a CTI2500 CPU via the ethernet port? There are only DP and serial selections for the Simatic 505 in the WinCC Flexible 2008. Anyone able to help? o_O
You might conisder to switch to a PC RT based solution.
That allows you to connect via OPC, which again means you can connect to any device for whiche there exists an OPC server.
An IPC + OPC Server + Flex PC RT license will be a bit more expensive than a TP277, but is definitely a possibility. It can save you a lot of time in comparison with having to learn a new HMI system.
edit: Does CTI support Modbus TCP ? That could be a possibility for the TP277.
Thanks for all your responses but I since located details making this project not possible. The reason to use the Siemens TP277 is due to having the stock on hand.
Thanks.(y)
Hi Gents I was wondering if anybody had setup a system where a live camera image was displayed on a TP277 touch panel with ethernet, The vision...
2,813
HI, A customer has a TP27 panel that was damaged. He replaced it with a TP277. I need to know what is invloved with uploading the software from...
2,494
Hi to all, I am working with TP277 using WinCC Flexible 2008(Advanced) software. In my project, I have developed 10 screens, in that I have to...
2,096
206
147
