Siemens TP700 Confort Screensaver Help
Nan
Jul 2015
louisville
126
Hi everyone,
I am using a TP700 comfort HMI and 317 CPU. I have been required to add four pictures to make the HMI screensaver. Ideally it should work this way, when the HMI becomes idle for 1 minute, the first picture appears, then after five seconds the second picture appears, then five seconds the third picture, five seconds the fourth picture, and five seconds go back to the first picture, and so on. If anyone touch the HMI screen, it should go back to the last screen before it becomes idle.
I went through the manual and looks like the HMI setting does not allow you to change the picture of screensaver. I was wondering if there is way I can accomplish this?
I am new to Tia Portal v13, if anyone have an idea, please be specific if you can. Thank you very much!:nodi:
You could load a certain screen containing the pictures in a graphic list? Then use a script on that page to cycle count a internal tag pointing at your pictures in the graphic list (SimulateTag).
Hi, I am using TP700 confort with 317 cup. The limitation is 512 tags for tp700, I am having 600+.... Is there any way I can extend the tag...
7,187
Long story short..... Customer : We want you to replace this hmi with a direct replacement. We don't have the original hmi program. Me: OK, I...
1,295
Hello great friends. Please help me....what is the easiest way I can RESET a Siemens TP700 COMFORT HMI Touch panel, to its Default...
1,242
Hello, I have a customer requesting me to duplicate an existing small well control system they already have that uses an S7-1200 and a KTP700...
2,134
We have a Siemens KTP700 Basic HMI. We do not have the source code file for it. There are some configuration screens on the HMI that are...
2,446
