Siemens Traversing Block Problem
Manoj M
Feb 2014
London
59
Dear Experts,
I wanted to discuss a problem which I am going through now and you experts can suggest me a solution for this.
I am using S120 servo's and using traversing to control the positions of the servo. The problem is every now and then, I am losing the Traversing Active signal from the drive and that cause no motions to servo. I can see that there is right traverse block number being fed to block plus also there is this bit activate Traversing Task which goes high but as I mentioned earlier, I am losing the Traversing Command active, which I believe comes from the drive status word.
Can somebody explains me how to trouble shoot this.
Many Thanks in Advance
Manoj
Too many things to guess...
Set up a trace for digital signals
I assume your not getting any alarms? it just stops?
Are you calling the tasks from the plc? (I see your using 2091.x for traversing block selection)
Thanks JRW for responding.
The traverse move number is active via 2091.x and also there is no alarms in the drive. Yes you are right, I am calling the tasks from the PLC.
I will give a try with Trace and see if that works.
Will post the outcome of it.
Regards
Manoj
HI everyone, i am new to Siemens plc programming and i am in need of some help. yesterday we had an S7-1200 CPU 1214C fail to turn on an output to...
160
Hi PLC people, think about this scenario: The PLC is somehow connected to the same network with the facilities` network. Then someone connects to...
84
Hello everyone, I've had this issue for the last 2 days where I try to assign the profisafe address to an IO block (6ES7 146-6FF00-0AB0) but when...
152
Hello, good morning, I have been having two problems with the Tia Portal software. The first is that I have installed it on my computer and...
184
Hello to all, I'm just starting with using CodeSys. Immediately, I have noticed that Codesys doesn't use data blocks like for example S7 does...
182
